Removing Gateways from a Project
1143 / 0
Follow the steps below to batch remove gateways from a project:
Step 1: Select the gateways you want to delete. Multiple selections are supported.
Step 2: Click More, and then click Delete.
Step 3: Click OK in the operation confirmation box to complete the operation.
In addition to the above deletion methods, you can also delete devices through the Delete button in the Action column of the gateway list.
