Configuration Logs
1783 / 0
Click Logs > Config Log to go to the configuration log interface. The configuration log interface is divided into two parts: Action View and Device View, which shows different viewing dimensions. Action View is based on the operation type, and Device View is based on the device SN.
Action View
The Activity View displays the latest record by default. Click + to view more information about the log.
If you need to export an operation log, click  to export the it. The imported configuration file is shown below:
Device View
In the Device View interface, you can view the configuration log according to the device's SN. Click the  in the Action column to view the push status of each configuration item.
