Sending Network Reports to a Specified Mailboxes Regularly
1066 / 0
Follow the steps below to send network reports to your mailbox at a specific time:
Step 1: Click .
Step 2: Switch to the Delivery Plan interface. Enable the scheduled delivery function, select the report format, enter the email address, and set the scheduled delivery time, then click OK.
Notes:
1. Click the + next to the email address to add multiple email addresses. Up to 3 email addresses are supported.
2. If the report document format is set to CSV, you can select the report content. If it is set to PDF, the entire content will be sent by default.
Step 3: After the “Succeeded” prompt appears, click X to close the prompt box and complete the operation.
