Changing the Account Password
2876 / 0
To changing your account password:
Step 1: Click the account icon and select Account to enter the modification interface.
Step 2: Go to the Security Setting interface.
Step 3: After entering the old password and setting a new password, you need to enter the new password again for confirmation, and then click Save.
Step 4: When the "Password change succeeded" prompt appears, click X to close the prompt box and complete the operation.
Note:  If you forget your original account password, please refer to Resetting Password to reset it.
