Plan Management
1004 / 0
Click [WiFi Heatmap] to go to the WiFi heatmap management page.
No.Description
1Create Plan button.
2Search input box by plan name
3Filter plans by scenario: Education Scenario, Hospital Scenario, Enterprise Scenario, Hospital Scenario, Common Scenario
4Sort by creation time: newest to oldest or oldest to newest; sort by plan name: A to Z or Z to A
5Pagination feature
Creating a Plan
Step 1: Click <Create Plan>.
Step 2: Fill in the basic information of the plan.
ItemsDescription
Plan NameRequired. Set the plan name. Up to 15 characters can be entered. Only letters, numbers, spaces, and the following characters are allowed: - _ # / . [ ] () = : + @.
Plan ScenarioRequired. Default: Common scenario
Plan DescriptionOptional. Up to 30 characters can be entered. Only letters, numbers, spaces, and the following characters are allowed: - _ # / . [] () = : + @.
Step 3: After filling the basic information, click <Confirm>. After the “Save Successfully” message appears, the plan is created.
Deleting a Plan
Step 1: Hover your cursor over the icon   on the bottom right corner of the plan to be deleted, and then click <Delete>.
Step 2: Click OK in the confirmation box.
Step 3: When the “Deleted Successfully” message appears, the plan is deleted.
Renaming a Plan
Step 1: Hover your cursor over the  icon  on the bottom right corner of the plan, and then click <Rename>.
Step 2: After changing the name, click <Confirm> to save the change.
ItemsDescription
Plan NameRequired. Up to 15 characters can be entered. Only letters, numbers, spaces, and the following characters are allowed: - _ # / . [] () = : + @.
Step 3: When the “Updated Successfully” message appears, the operation is completed.
Copying a Plan
Step 1: Hover your cursor over the icon  on the bottom right corner of the plan, and then click <Copy>.
Step 2: When the “Copied Successfully” message appears, the operation is completed.
Importing a Floor Plan
Note: If the current floor has no floor plan, the import function will appear.
To import the WiFi heatmap of the corresponding floor:
Step 1: Drag a floor plan into this area or click to upload a floor plan.
Step 2: When the "Upload Successful" prompt appears, the import is completed.
