Floor Management
1013 / 0
Afer creating a plan, click the plan to go to the floor management page.
Creating a Floor
Step 1: Click <Create Floor>.
Step 2: Fill in the basic information of the floor.
ItemsDescription
Floor NameRequired. Up to 30 characters can be entered. Only letters, numbers, spaces, and the following characters are allowed: - _ # / . [] () = : + @.
Actual FloorRequired. Set the actual floor number. Range: -200 to 200
Floor PlanOptional. Set the floor plan. The supported formats include PNG, JPG, PDF, BMP and DWG. File size must not exceed 5MB. Only one file can be uploaded.
Editing a Floor Information
Step 1: Hover your cursor over the   icon, and then click <Edit>.
Step 2: Change the information as needed, and click <Confirm>.
ItemsDescription
Step 3: When the “Updated Successfully” message appears, the operation is completed.
Copying a Floor
Step 1: Hover your cursor over the   icon, and then click <Copy>.
Step 2: When the “Copied Successfully” message appears, the operation is completed.
Deleting a Floor
Step 1: Hover your cursor over the  icon on , and then click <Delete>.
Note: The default floor cannot be deleted.
Step 2: When the confirmation message appears, click <OK>.
Step 3: When the “Deleted Successfully” message appears, the operation is completed.
