Operation Bar
1374 / 0
ButtonsDescription
 Undo the previous action on the canvas. You also can press Ctrl+Z.
 Redo the next action on the canvas. You also can press Ctrl+Y.
 Fix to screen.
 Display or hide the wall on the canvas.
  Set the scale of the canvas.
 Draw walls. When you click on the wall, a checkbox appears. Checking the box will display the wall, while unchecking it will hide the wall.
 Identify walls.
Setting the Canvas Scale
The canvas can be set by length or by area.
  • By length
Click the  icon, and set the length.
  • By Area
Step 1: Click the  icon, and set the length.
Step 2: Draw a line segment on the canvas.
Step 3: Enter the actual length (required; range: 0-9999)
Step 4: Input floor height.
Step 5: Click the <Confirm>.
Step 6: If the message "Setting Successfully" is displayed, it means the floor scale has been set successfully.
After setting the canvas, the signal coverage map will display the heatmap accordingly
Wall Operation
(1) Drawing a Wall
Step 1: Click the  to enter the wall drawing function. When the draw instruction appears, it means that you can draw a wall.
Step 2: Left-click the mouse (hold down ALT to draw a rectangle, or hold down Shift to draw a straight line).
Step 3: After drwaing the walls, right-click the mouse or press the Esc to exit drawing function.
(2) Modifying a Wall
Move the cursor onto a wall, and then two bule dots appear on its two ends. Right-click and drag the blue dots to modify the wall.
(3) Copying a Wall
Step 1: Hover the cursor over a wall and right-click. Then click <Copy>.
Step 2: Move it to a specific location.
Step 3: Right-click or press Esc to exit the wall copy function.
(3) Disconnecting a Wall
Step 1: Hover the cursor over a wall and right-click. Then, click <Disconnect>.
Step 2: When the operation instructions are displayed, it means that the wall can be disconnected.
Step 3: When the cursor moves to the wall, a blue dot appears on the wall.
Step 4: Click the blue dot  to disconnect the wall.
Step 5: Right-click or press Esc to exit.
(4) Deleting a Wall
Step 1: Hover the cursor over a wall and right-click. Then, click <Delete>.
(5) Editing Wall Properties
Step 1: Left-click a wall.
Step 2: The properties of the current wall are displayed on the right.
ItemsDescription
Obstacle materialRequired. Select an option from the dropdown
Obstacle thicknessRequired. Range: 0-100m
Step 3: After setting the parameters, click <Save>.
Step 4: After the "Updated Successfully" message appears, the modification is completed.
Identifying a Wall
Step 1: Click the  icon.
Step 2: Click <OK> in the confirmation box.
Step 3: When the "Setting Applied" message appears, and the wall are re-identified.
2.4G WiFi Heatmap
Click  to display 2.4G WiFi heatmap.
5G WiFi Heatmap
Click  to display 5G WiFi heatmap.
Hidding WiFi Heatmap
Click the  to hide signal simulation.
Clearing the Current Canvas
Step 1: Click the  button.
Step 2: When a confirmation box appears, click <OK>.
Step 3: If the "Clear Successfully" message appears, it means that the devices and walls of the current canvas have been cleared.
Exporting a Plan
Click <Export> to generate a work file for the 2.4G signal and 5G signal of all floors of the current plan and export it.
